Cooktop/double oven wiring and armor question
Old 01-20-13, 03:00 PM
Hello all,
Long ago with the help of some folks on this forum I ran a new 6-3 wire from my main panel to my kitchen for a cooktop. It has been many difficult months since then and I've finally installed the cabinets. I am ready to wire the appliances and I have a question. The 6-3 NM wire in my sink base will be exposed for a few inches inside of the cabinet until it goes inside of a junction box. Does this section need to be armored?
The cooktop and double oven wiring are armored already. Thanks all.
Old 01-20-13, 03:08 PM
Justin Smith's Avatar
I do not believe it is required, but a piece of conduit over the cable never hurt.
Old 01-20-13, 04:23 PM
Code states the wire must be protected if in an area subject to damage. Because of where it's located and the fact that the junction box will likely protect it from any errant cereal boxes or whatever that might be shoved in, you should be good to go.
In my opinion, you're fine... but the only person who can answer with certainty is your AHJ (local electrical inspector).
Old 01-20-13, 04:31 PM
pcboss's Avatar
I would not consider it subject to damage, but like Mike said, the inspector has the final say.
Old 01-20-13, 05:32 PM
Hi I finished installing it. I have attached a picture. Please let me know if it looks good to you.
Also, how would you recommend I fill that hole above the armored cable hole? I can try shoving wood filler in it but I was wondering if you guys had better methods. Thanks.
Old 01-20-13, 07:49 PM
Also want to mention that our township follows the 2008 NEC code.
Old 01-20-13, 08:05 PM
I'd use duct seal or silicone.
Old 01-20-13, 09:20 PM
ray2047's Avatar
I might glue a 1x1 on each side of the cable and a strip of 1/8" Masonite on top of the 1x1s.
