cleaning soldering iron tip
Here's a picture of a few soldering irons I had laying around. Don't know much about soldering but I think these tips may need cleaning. I'm gonna attempt soldering an alligator clip onto a multimeter lead. Just heat up the iron then wipe it on a damp sponge to clean it?
thanks for any "tips", pun intended. http://i207.photobucket.com/albums/b...psd611b7b1.jpg
Yes.....wipe on a damp.....not wet sponge.
Immediately put fresh rosin core solder on tip to recoat it.
PJ has it right. Not always possible at a job...but thats the right way. 8 wks of soldering school for the Navy taught me that.
Oh...no cracks....it was one week of basic techniques then 6+ wks of miniature work on circuit boards.
The layer of freah solder keeps the tip from oxidizing.
I do a LOT of soldering. I sometimes have several bench irons running at once. They are all variable heat setting type....set for the job. Heat kills the tips. I use all Weller soldering irons. It's also very important to not scratch the plating off the tip. Sanding a plated tip is disastrous for it.
Some of the inexpensive soldering irons use non plated tips and they get eaten fairly quickly.
A can of tip plating compound can be helpful too.
If the tip was allowed to get oxidized, is the tip effectively ruined in that case? These irons I have happen to be Weller brand, probably relatively inexpensive models (I have no background info on them or their past use). Thanks again for the helpful replies.
The way we were taught was to be ready to solder, clean tip (w/o applying solder afterwards), solder the connection, apply solder to the tip til it almost starts to drip off, put it back in the holder. Repeat for next connection. If you have multiple connections ready to solder, you can just do them all at once w/no cleaning in between.
If possible surfaces to be joined should be cleaned with isopropyl alcohol. Not rubbing alcohol, which may contain glycerin.
That's correct.
Clean tip.....solder your connections and then apply fresh solder before putting iron back in stand.
I've had a Weller 25 watt iron with the same "Iron Clad" tip since 1981 or so. All I've ever done is clean it with a piece of damp sponge and re-tin it after cleaning. It gets used at least once a week on job sites.
BTW, carbon on a tip won't damage it but it does stop it from efficiently transferring heat.
Also a Navy 2M (miniature and microminiature) grad.
If a tip is severly oxidized or pitted it should be replaced. Most tips are iron clad copper and once the iron layer is compromised the tip will not transfer heat evenly. Never use an abrasive on the tip because it removes the iron cladding.
Also don't wipe the tip more than necessary. Repeated wiping when the tip is hot causes temperature variations that can cause the tip cladding to fail.
The most important thing is to tin the tip when you are done soldering. Don't put the iron away when the tip is covered with burnt flux and solder residue.
The tips on my irons don't necessarily look severely oxidized to me, nor pitted at all, but there is perhaps an amount of carbon buildup on them that could be preventing efficient heat transfer (not sure how dark/black the tip area should appear before you can tell if it's too "carboned up"). Is there a way to tell whether the iron ladding has been compromised and if so whether it might be time to just replace the tip(s) if that's the case? Is there a proper method to clean a tip of carbon if an abrasive should never be used?
There shouldn't be any blackened crud on the part of the tip used to apply heat. It should be bright and shiny. A damp sponge will probably get the black crap off but you can also get a mesh type cleaner that is less likely to lower the tip temperature.
