no power after plugged in hairdryer
Old 01-27-13, 02:09 PM
B
My wife plugged in hair dryer this morning and then lights in bathroom went out and also no power at receptacle or at switch. Metered receptacle and switch 0 volts. Metered breakers all at 120v not sure where to go from here? there are no gfi receptacles in the house
Old 01-27-13, 02:11 PM
XSleeper's Avatar
Received 338 Votes on 310 Posts
Reset the GFCI on the outlet, or on the one that is in series with that outlet?
Old 01-27-13, 02:17 PM
B
there are no gfci outlets in the house
Old 01-27-13, 02:21 PM
XSleeper's Avatar
Sorry, didn't see that! I'd probably remove the outlet and/or switch and see if you have power to the outlet/switch. I've seen a few instances where a back stabbed outlet just happened to have a wire come out of it's socket.
That happened to me the other day and at first I thought the switch on my sawzall was finally going bad, but it was the outlet itself.
Old 01-27-13, 02:29 PM
B
i removed the receptacle and switch. no loose wires. metered the wires in the box and no voltage, then though I had a bad breaker so I metered the breakers and all have 120volts but no volts at the switch or receptacle wiring
Old 01-27-13, 02:38 PM
XSleeper's Avatar
I would next remove outlets that are in the same circuit and check them for power. Since you have power at the breaker it sounds like you've lost continuity somewhere along the line.
If you know which breaker runs the bathroom that might help you identify which outlets are on the same circuit.
Old 01-27-13, 02:47 PM
B
i'll do that now thank you
Old 01-27-13, 06:45 PM
pcboss's Avatar
Received 44 Votes on 39 Posts
