Surge suppressors to test wall outlet ground?
Old 01-28-13, 11:30 AM
Are the ground indicator lights on surge suppressors reliable for testing whether wall outlets are grounded properly?
Old 01-28-13, 04:02 PM
Nashkat1's Avatar
No, surge suppressors are not designed and are not rated to be used as electrical test equipment.
There are two tools you can use to test for ground. One is a plug-in receptacle tester. Get one that also tests for GFCI protection. The other is an inexpensive analog multimeter. Example: Craftsman Analog Multimeter
Old 01-28-13, 04:37 PM
Justin Smith's Avatar
I find them to be pretty reliable. Most of the cheaper ones I've found to use an LED between line and ground. My APC's and Tripp Lite's use some fancy circuitry.
Old 01-28-13, 06:14 PM
Thanks. This question is related to another thread I started about electrical shocks and computers
None of the stores sell anti-static spray. Guess I'll have to order it online
