Using a lower wattage voltage converter
Received 0 Votes
I was ignorant and did not consider the specs of a Vitamix kitchen blender before plugging it into a 300-watt step-down voltage converter. However, both the blender and the converter worked fine for many events and continue to do so, which baffles me as I'd expect there to be a major problem since the Vitamix actually requires about 2500 watts (120 volt rated blender that takes 11 amps and is 2 horsepower). I live in Singapore which is 220 V.
My questions are:
1) Does 2 Horsepower mean you multiply the wattage requirement by 2?
2) Why does the blender still work on such a lower watt converter that should not support it?
3) What is the risk of using the blender on this low watt converter?
Thanks for help on this issue.
My questions are:
Welcome to the forum. I'm a little confused....you said you're from Singapore but you registered in Illinois.
Your unit uses 1320 watts. 120v x 11a = 1320 watts max.
Since you're running that device on 220v....it would be 1320 w /2 = 660 watts max @ 220v
I think most of those inverters are a step down transformer......and are forgiving of an overload.
I would think that with extended use that the converter would get fairly warm.
Received 0 Votes
Thanks, I wonder if I used the right terminology when I said "step down" -- my converter converts from 220 - 120 but also vice versa, via a switch. Yet it is rated at 300 W, so I suspect if it is converting to the 120, then my blender still requires the full 1320 watts since the output is 120.
The specs on this converter are listed on it here:
http://cdn.sulitstatic.com/images/20...825d43b55f.jpg
To answer your question, I am from Illinois but living in Singapore for a while.
I believe it's a basic transformer.....nothing more.
I would think that if you were to put too much load on the converter it would either die or pop an internal fuse.
1320 watts is a lot of power for a kitchen blender. It may run at a lot less.
