need help wiring a 3/4 hp 40 amp electric motor
Received 0 Votes
I work for a snow plow company in Chicago and I have an issue with a salt spreader that is designed to run on a gas powered small engine like our other trucks, but it has been modified to run off of an electric motor. It has a battery isolation switch ran to a battery with 8 or 10 gauge wiring running directly into the cab and the driver controls this switch on and off to operate the spreader this is all good until the spreader jams up; then the switch becomes very hot and starts to melt. now I am no electrician, but isn't there better a way to wire a heavy duty remote switch like a solenoid that receives a signal from a switch to engage the high amp motor from outside the cab and shouldn't there be a safety device like a breaker or fuse somewhere in the setup any advise on what to do or where to look for answers would greatly be appreciated
You should be using a relay/contactor like the following:
Solenoids & Relays | Steel & Phenolic Body Solenoids24059 | Cole Hersee - Littelfuse
and a circuit breaker like:
Bussmann Hi-Amp Reset Circuit Breaker - 100 Amps : Amazon.com : Automotive
I just left you the links to show you what I use. The circuit breaker and contactor would go near the supply battery for the salter.
Yes......the control switch in the cab should be a low amp pilot duty switch only.....controlling a solenoid mounted at the electric motor.
Is this a 12 volt starter type motor?.....is it directly coupled to the spreader or does it drive a small hydraulic pump?
