Framing Around Electrical Panel
Old 02-05-13, 06:03 PM
Can anyone give me picture of how to frame around an electrical panel?
I am in the process of finishing my basement and would lke to know before I get there. I cannot find anything on the internet.
Not the codes for it but the actual way to frame around. Do you do it like a window? If so how would you do the top where the wires come out of the box?
Will I have to Block Nail it since the floor joist are running parallel to my wall?
Thanks for any help.
Old 02-05-13, 06:39 PM
ray2047's Avatar
I have moved you to Electrical because there are code issues involved.
Old 02-05-13, 06:47 PM
chandler's Avatar
Most panels will fit inside a 14 1/2" opening, which is the spacing between two studs. Not sure what the floor joists have to do with the framing of a panel. You place the panel between studs, fasten it in and the cables emerge from the top or bottom inside the stud cavity. No further "framing" is necessary. Picture?
Don't laugh.
Old 02-05-13, 07:04 PM
No way will I laugh when someone is providing help.thanks
What if the wall does not layout to have the panel in between studs?
Old 02-05-13, 07:31 PM
ray2047's Avatar
What is your layout if not studs on 16" spacing? A picture might help us understand. http://www.doityourself.com/forum/el...-pictures.html
Old 02-05-13, 07:34 PM
If I'm not mistaken.......the OP already has a panel on the wall and wants to frame around it.
Is that correct ?
Old 02-05-13, 09:57 PM
Nashkat1's Avatar
It will probably be easier to shift the layout than to move the panel.
Separate question: How are the wire coming out of the panel secured?
Old 02-06-13, 05:44 AM
In my mind, you have two options:
1) Basically do what Larry said and mount the panel to your new stud wall. Unless you're comfortable around the main panel, it will probably require a call to an electrician, since there are parts of the panel which are always live. The good thing though is that it should be a quick and easy job for the electrician, so not too much $$. This will end up looking the best since the panel cover then goes on after you drywall.
or
2) Leave the panel mounted to the block wall as-is. Build the wall around the panel as if you were framing a window. Then add a pair of cabinet doors to 'hide' the panel. Easier, but the downsides are less insulation (difficult to insulate around the panel). Also, you'll need to keep the 'window' large enough for future work in the panel.
