Garbage disposal
Received 0 Votes
Garbage disposal
So my current disposal has a leak in it. I have small children so we decided to purchase a batch-feed model instead of a continuous model. My current disposal is hard-wired, while the new model is a three-prong plug.
What's the ideal setup as far as safety and ease of installation? Should I cut the plug and hard-wire it? Or should I install a GFI outlet under the sink? I am comfortable with very basic electrical installations. I have replaced/installed outlets, fixtures and dimmers in the past.
Many thanks for your assistance.
Install a receptacle. You can use a simplex receptacle if you want. By code no GFCI required simplex or duplex. If switched I'd go with simplex but that's personal choice. If simplex not duplex receptacle and only device it must match the breaker.
Received 0 Votes
Ray, WOW many thanks for your input. A couple of follow on questions...
1) Simplex (one plug) duplex (two plugs), any other differences I need to be aware of?
2) You said by code that no GFCI is required? My home inspector had mentioned that some states require GFCI if the outlet is within a certain distance of water sources. Wouldn't that apply here?
3) What do you mean must match the breaker? The current disposal is on a switch, was kind of planning to keep it that way. The batch feed disposal requires a cap to be placed over the drain before it will run. If it's hooked up to the switch also, its kind of a double safety feature. Right?
Sorry, sometimes I get carried away with my answers. I probably shouldn't have even mentioned simplex. When a simplex receptacle is the only device you must use a 15 amp receptacle on a 15 amp circuit and a 20 amp on a 20 amp circuit. That does not apply if there are two or more places to plug in such as a duplex receptacle so you can use a 15 amp duplex on a 20 amp circuit.
It is my understanding the circuit under the sink is exempt from the "near water" requirement when used for dishwashers and garbage disposals. Wait for the pros to confirm.
and removing the plug will destroy the U.L. listing of the unit.
Is that written somewhere? I would like to read it, and if true I need to tell some folks about that.....
What would be the difference in UL listing plug vs no plug?
Confirming Ray's understanding about receptacles inside sink bases.
