how do I find out if my 200amp service has blank slots for me to get 220v at 10
Received 0 Votes
I have a 200 amp service.
I need to put a new wire in for 220v at 10 amps. It's to a radio.
When I walk up to my panel. how do I know if there are enough spaces to allow me hook breakers up to it to get this run?
What kind of wire would I use? Romex 3 wire and ground, 12 ga?
What size breaker would I use? 220v 15 amp?
Received 0 Votes
This is a radio made in the US. It's a Heath Kit final, SB-221. It can draw 10 amps on 220v for a few seconds, less most often.
No, I don't have electricians hired.
What I'm trying to do is get a feel for what can be achieved, or what may not be.
Someone said no 10 amp 220v breakers. Fine. What's the next size?
I also need to know, when I look at my panel, how do I know if I have enough space for 220v 15 amp circuit?
Once I get some of this basic info, then it's time to hire an electrican, get permits, etc.
The model number you gave is not for a radio. It is for a linear amplifier. Is that what you have? Acording to this spec sheet it may be able to operate on 120 volts. Linear Amplifier SB-221 RF-Ampl. Heathkit Brand, Heath Co.;
Follow up: It will run on both 120 and 240 but supposedly the power regulation is better on 240. Heathkit SB-220/SB-221 Product Reviews
240V hot-to-neutral and 220V hot-to-neutral are supplied in other countries, Not here.
Post a picture of your breaker box with the cover removed and we may be able to answer your question. Also we need to know the make and model number of the breaker box. You will need a 15 amp breaker and 14-2 NM-b assuming the amplifier is in the same building as the breaker box.
Rbig, if you give us accurate and complete information in your first post things go smoother. Had you said you were a Ham needing to run power to a linear amplifier on your transmitter we would have better understood your situation and not had to guess because of incomplete and misleading info.
Received 0 Votes
There are reasons for lack of answers as each panel is made differently and no one here has seen yours so far. In some cases a space saver breaker may be needed etc. however here is the simplest thing I can think to tell you...Normally you would open your panel door and look to see if there are any "blank" unused spaces. Companies usually put a metal removable knock out for every full sized single pole slot there is. Say yours is a 40 circuit panel it should have 40-1 pole spaces. Two of them would combine for one double pole circuit. You should have both single and doubles in there already....So if you have two slots together you should easily have what you need....the issue is if it is near full or someone has loaded it with space savers or the cover has been replaced etc.....A picture would help a lot.
You use 220v so the amp draw is halved. Better regulation too.
Rbig, can your linear transformer take single-phase 240V?
Other forums, other people .........
