Service Size for Single 1,500 Watt BB Elec Heater?
Old 02-13-13, 03:32 PM
I am adding leanto to the side of my garage and plan to put a single 1500 watt/240 volt BB elec heater in it to keep things from freezing. My math says that would only draw about 6 amps, so a 15 amp/240 circuit would be adequate. Can someone confirm. It's been 50 yrs since I got out of school. Thanks.
Old 02-13-13, 04:39 PM
ray2047's Avatar
1500 240 = 6.25 so yes 14-2 UF-b on a 15a breaker will be okay. The code question would be if the lean-to is part of the garage. If it is and the garage already has power you can't run a second circuit.
Old 02-13-13, 04:43 PM
How about we just call it an additional circuit rather then another service.
Old 02-13-13, 05:00 PM
ray2047's Avatar
Post corrected to circuit.
And do you think it counts as a separate detached structure?
Old 02-13-13, 05:57 PM
CasualJoe's Avatar
For what it's worth, my opinion is that if it is attached to the garage with no passageways (doors) between the lean-to and the garage, it is part of the garage unless it is separated by a firewall. A single structure separated by firewalls can normally have a service to each section. Think about a strip center, all stores are technically the same structure, but they are all separated by firewalls, thus each store can have it's own electric service. Or....... a modern duplex.
PJ, ray, what do you two think?
Old 02-13-13, 06:21 PM
ray2047's Avatar
I like your reasoning Joe but what if he wants a light in it? A 240 volt fluorescent light? Probably 14-3 and a 2 space subpanel would be cheapest.
Old 02-13-13, 10:12 PM
Nashkat1's Avatar
I don't see anything in the OP to indicate that everything including the new shed isn't all part of one structure.
Old 02-13-13, 10:20 PM
You are probably right.....it's technically part of the garage.
Old 02-14-13, 05:41 AM
"If the garage already has power you can't run a second circuit."
I know what the code says but really don't understand this restriction. Can someone explain the reason for it? Makes no sense to me.
Old 02-14-13, 06:54 AM
ray2047's Avatar
The code doesn't explain it dictates. Any answer would be best guess but I'd be interested also. There are even in the code exceptions when you get into industrial wiring.
Old 02-14-13, 07:02 AM
Thanks for all the responses. However, a lot of these nuances are sliding right past me. FWIW, I am not permitting this and wouldn't do anything that I considered unsafe. I am just desperate for add'l storage space that is slightly heated so I can store paint, etc. There will not be any passage way from garage to leanto.
Old 02-14-13, 07:41 AM
ray2047's Avatar
What you do is your final decision but the forum can't officially endorse code violations.
If the garage is currently served by conduit there is a simple code compliant solution. Add one wire to that conduit and install a subpanel in the garage. Option number two would be to run 12-3 UF-b to the lean-to instead of 14-2 and put a subpanel there to supply both the lean-to and garage. Then abandon the cable to the garage. Even if you went non-code the last solution is about the same amount of work and costs only slightly more.
Old 02-14-13, 10:03 AM
The garage already has a 60 amp sub panel coming from my shop. This was permitted and installed by a licensed electrician 9 years ago. Both shop and garage are detached and separated 30-50 feet from the house. Thanks for all the suggestions.
Old 02-14-13, 11:28 AM
ray2047's Avatar
Now why didn't you say that eight posts ago? You are golden then. Just run from that subpanel.
Old 02-14-13, 11:30 AM
Nashkat1's Avatar
Thanks. More information is almost always helpful.
Adding a dedicated 15A 240V branch circuit to your existing subpanel should be as legal as sunshine. The only codes regulations you should have to worry about should be the ones covering wiring methods.
Old 02-14-13, 11:35 AM
Sorry Ray. My original question was just about wire size.
