Is it possible
Received 0 Votes
Hey all,
I read in an article a while back that it is possible to return the power to the grid and lower your energy bull using nothing but capacitors, resistors, and fuses to wire a circuit to return power to the grid thus reducing power costs and consumption.
Furthermore if it is possible would someone be willing to diagram the circuit for me so I can test this out?
Thanks
David
Thanks
David
In that link they give another link that is no longer functioning.
The circuit you are talking about does work. It actually generates power from the air. It uses a long antenna wire......it then rectifies the ac antenna waves into dc.....sends it thru a basic charge pump circuit and then you get higher ac voltage out of it.
There is a kit you can buy with the parts. I think it goes for about 10-15 bucks.
If you ran the circuit for an entire year you might just recoup a part of the cost of the kit.
