Door-activated cabinet lighting
Old 02-21-13, 07:46 PM
T
I want to install some rope lighting in a cabinet, and I want it to be activated by opening the door. The rope lighting is line voltage (120 V). What are my options?
I was thinking of a low-voltage magnetic switch at each door, connected to a relay that activates the light. But I'm having trouble finding a relay that can be mounted in a junction box.
The other option is to use line-voltage switches, but the only ones I can find are for door jambs, and these are way too big for the application.
I'd appreciate any tips you can provide. Thanks!
Old 02-21-13, 08:46 PM
Received 2,683 Votes on 2,435 Posts
You need a low voltage controller and power supply in one package.
One product that is 100% perfect for your application is the Sensor Switch PP-20.
I use them all the time for applications like yours. It's everything in one compact package. Connects to an electrical box using a 1/2" knockout.
Here's a link from Amazon. You'll find them at several online companies.
Amazon.com: SensorSwitch PP-20 Power Pack w/ Circuit Protecti: Camera & Photo
Old 03-12-13, 08:19 PM
T
It's been a few weeks, but I wanted to close the loop and say that the PP20 solved my problem completely. I bought several of these from eBay and they are just what I needed. Thanks!
Old 03-12-13, 10:12 PM
I'm glad they worked out for you ........ an awesome module.
