Circuit for Tankless Water Heater
Old 02-23-13, 12:56 PM
I am running some additional circuits for various things. I want to get a Rinnai tankless gas water hater in the future and I understand it needs 120VAC to operate, presumably for control functions only. Looks like it draws very little current so a 15A circuit would be more than sufficient. Question- Is there a requirement (code or otherwise) that this be a dedicated circuit or can I just run it off an existing lighting/outlet circuit? Also, can anyone tell me if this heater requires an outlet or is it hard wired in to the heater? Thanks! Jay
Old 02-23-13, 01:05 PM
pcboss's Avatar
Unless the instructions call for a dedicated circuit you should be able to add this to an existing circuit, providing there is enough reserve capacity in the circuit. This assumes you are adding a gas tankless WH.
Old 02-23-13, 03:14 PM
You didn't specify a model number, but for the most part, gas tankless heaters usually come with a cord and plug. I believe they can be hardwired but it would require a service disconnect within sight of the unit. And you are correct, in a gas tankless, the power connection is just for the control and ignition functions. A couple amps tops while in use, less than an amp in standby.
Old 02-23-13, 07:41 PM
Thanks for the replies!!!!!!!!!!!!!!!
