Kitchen Remodel Electrical ??
Received 0 Votes
I am remodeling my kitchen (Cabinets, Flooring, Counter Top and Backsplash) and have some questions regarding electrical. The house was built in 2001 and is in NJ....
About 6 mo ago I added a garbage disposal and tied it in to a dedicated 20A dishwasher circuit (new receptacle under sink base for both DW and Garbage Disposal), is that up to code?
I plan on adding hardwired under cabinet LED lighting but am aware that I can not tap into the backsplash small appliance receptacles. I plan on tapping in to a receptacle on a wall opposite the cabinets in the dining room, will that be in compliance with code?
The original kitchen is wired with the refrigerator on the same circuit as the kitchen backsplash receptacles and the OTR microwave (which does not vent to outside, vent is on the front) is on the same circuit as some of the lighting in the basement. I think the refrigerator is OK (as far as code) but from what I read online, the microwave should have its own circuit. If some of that is not up to code, do I have to fix it since I am remodeling, or can I just leave it? (in 7 years at this house, I have never had lights flicker or a breaker trip).
Received 0 Votes
Depends on your local codes some allow it and some do not. There is little chance that the dishwasher and disposal will overload the circuit but since you are ripping everything apart might as well pull another circuit for the disposal. I usually use a mwbc and put them on their own circuit.
No the dining room receptacles cannot serve the lighting in the kitchen.
The refrigerator can be on the small appliance circuit but it is best practice to put it on it's own circuit. Also the microwave should get it's own circuit. The kitchen lighting can share a circuit with other lighting circuits in the house.
Received 0 Votes
why cant I tap into the dining room for some LED's in the kitchen, that is ridiculous...
Dishwasher and disposal have been fine for the past 6mo, so if its not against code, ill leave that...
Same with the fridge on the kitchen small appliance circuit...no issues in 7 years, im guessing there won't be any, so im not changing it for the sake of changing it...
With the microwave, you said it "should" get its own circuit...but does it have to to be in compliance? If not, im leaving it, again its been 7 years with no issues and id rather just leave it...
I should just do the whole renovation without permits...and keep the govt the F%$ck out of my house...
Received 0 Votes
my preference is to put the refrigerator on the lighting circuit
Received 0 Votes
Thanks for all the reply's so far...
I know what people are saying is best (ie, refrigerator, dishwasher, microwave, etc... on their own circuit) but im trying to do this reno with the least amount of electrical work possible and still keep it to code...
I am going to pull the permits, but id rather not hire an electrician. Since im doing it myself, and the kitchen has served me with not one tripped breaker or flickering light for 7 years id just as soon leave it how it is (im not changing any layouts, moving any lighting or adding any new appliances). If something was not done to code before I purchased (IE; microwave on basement lighting circuit) I assume I have to fix it...
Many of the codes seem way overkill to me, but again, im not an electrician. So...like I said, since things have served me well, im just looking to find out what I need to fix to be in compliance, not because its better to do it one way or another.
From my research:
2 circuits for the backsplash, 20A each, GFI protected, and spaced properly(no lighting or permanent appliances attached)
Double Wall Ovens on separate circuit
Electric Cook Top on Separate Circuit
Refrigerator can be on one of the 20A backsplash circuits
Separate circuit for dishwasher, garbage disposal may be connected to this circuit
Microwave should be on its own circuit (just checked the manual and it says it should be)
Kitchen Island receptacle can be connected to one of the 20A GFI backsplash circuit
Looks like ill be running one new line for the microwave. Did I miss anything else important??
Last question...
If my kitchen lighting circuit is not readily available in the walls behind the cabinets (aka the only ones im messing with) can I run under cabinet lights to other receptacles in the kitchen (other than the 2 backsplash circuits). If not, can I tap a receptacle in a hallway opposite the refrigerator (since im told I cant use the dining room circuit)
One more...are there any codes regarding a vent? I have an electric range with a microwave over it. The microwave does not vent to outside, it just recirculates through a filter...I assume that is fine, but just want to double check...
Thanks in advance...
From my research:
Last question...
Received 0 Votes
My bad, I misread Exception 2 before I opened my yap. I know a lot of old timers did that and it is a perfectly reasonable idea.. When did that change, if anyone knows?
Received 0 Votes
I don't think venting is actually required by code for the kitchen, but as someone who also owned a recirculating micro-hood (until I got tired of scrubbing grease that the filters didn't catch off the cabinets and ceiling), if you are renovating, you would be much better off running a vent if it is possible.
Kitchen lighting can be on any general purpose circuit. The dishwasher/disposal circuit would be fine, because it is not a SABC or required/mandated IBC. The hallway outlet would also be fine.
I would run a separate SABC for the island, just to cover future needs you may have not considered. Also, remember countertop receptacles can be no more than 4' apart (there can not be more than 2' of contiguous countertop in any direction from any receptacle. That goes for the island as well if it contains a sink/cooktop.. Even if it doesn't have a divide, I would still install one at each end if it is more than 4' long just for convenience.
Regarding the receptacles in the dining room: You can't add lighting to either of the two 20A SABCs that are required in the dining room. If you have a third, general purpose receptacle circuit there, you can add lighting to that.
Yes, you can add to a general purpose receptacle circuit in the hallway.
This brings up an important point. All codes is local. We can advise you on best practices, and on the requirements of the NEC and other model codes. While best practices are best practices, the code that controls the work you're doing is the one adopted by your local jurisdiction. To get the very best advice on what is and isn't allowed, and the best way to do the work, draw out and specify everything as you envision it and take that plan with you when you go to get your permit.
You may also have to pass a test to get a permit to do your own work. I did once, many years ago.
Enjoy your renovated kitchen, and the journey to completing it!
