Wiring Help Needed- 3 way, Switched Outlet, Power Outlet, Source - Same Box
Received 0 Votes
It was working. I took it apart and mislabeled something and can't get it to work again.
From panel- 14-3
14-2 to straight outlet string of 2 receptacles
14-2 to two lights on a three way, and a separate switched outlet
There are three wires total coming into the box.
The 14-2 basically is functioning as the lead for two lights and a switched outlet. The lights are switched elsewhere too. A 3way and single pole are controlling that 14-2.
Then there is the wire from the adjoining additional outlets that receives its power from the same source as the rest of the box.
I need to wire a single 14-3 from the panel, feeding power to both the lights/switched outlet and additional outlets, in conjunction with the 14-2 that controls the lights and switched outlet, between two different switches 3way & single), all in the same box. I know it's possible, as stated it used to work.... Help please.
From panel- 14-3
From panel- 14-3
Above assumes this is not a multiiwire circuit. That is the only time you would use a 3-conductor cable on 120 volt general purpose wiring.
It's a little confusing but you seem to be missing a wire.
You have a 14-3 feed from the panel ??
A 14-2 feeding two lights and a receptacle
Another 14-2 feeding just two receptacles
Where is the 14-3 going to the second three way switch ?
Received 0 Votes
My guess is power comes in from the panel at one of the switches, and there is 14/3 between switch 1 and switch 2.. The 14/3 presumably contains a switch leg and a constant hot for the circuits in the ceiling box...
That's just my opinion though, we would need clarification from the OP as to what each switch box contains..
Received 0 Votes
Clarification: I can retrace the cables (to use the terminology from a previous reply), but based on meter readings, the 14-3, odd as it might seem, is the power feed from the panel into the switch box.
Let's go with the assumption I am wrong, and the cable which is a 14-2 is the line that comes to the box as the power source. If this is the case, how would I wire accordingly?
There were pigtails and jumpered/bridged wires between the switches... I didn't keep track of them properly.
From the easiest to the most confusing, I have, at the double gang box, a cable that comes from a set of outlets requiring a leg of power in this mess. Then, I have two cables coming from above, one goes to the panel, the other to the lights and switched outlet. I have two switches in the mix, one single pole, the other 3way.
Somehow, with a single cable for power, this box was providing power and switching to what could be classified as 3 different things: outlets, a switched outlet (single pole switch for this one), and two ceiling fans (3 way for these). The lights and switched outlet are receiving power from another line/circuit not involved here.
I
I
- Black to White
- Red to white
- Red to Black
- White to Ground
- Red to Ground
- Black to Ground
Several other questions but lets get answers to these first.
