Outlet trouble
Received 0 Votes
Outlet trouble
I have a switched out let in my bed room. It was giving me issues where i had to jiggle the plug around for it to work and if you tapped it, it would cut out. I replaced the outlet and now i cannot get it to work at all. Im almost positive all wires were put in same order. The way its wired is confusing for me ive posted some pics so you can see. I would like to know if it wired correctly. Im pretty sure the wire on the right is coming from switch.
Yes it is wired correctly and yes the wire on the right is the one that goes to the switch.
The two black wires are hot where that white wire is connected that goes to the switch.
(that white wire is not a neutral so it should be colored or taped another color)
You did not take this connection apart.....correct ?
The black wire coming back from the switch is the switched hot.
It looks like you have two white wires/neutrals on receptacle. Normally these would be combined in a wire nut and one tail would be brought out to receptacle.
If the receptacle is dead you'll need to break out the meter to check for where it's being lost.
Received 0 Votes
So i d/c the switch and just wired it like normal but the outlet is still not working. I check each plug /w volt meter when connecting hot to ground i get 120 and the same for cold to ground 120 but it i test cold to hot i get 0. unsure what the problem is any ideas?
You're getting 120 vac from white to ground ? Something is not right there.
Was this receptacle working correctly before ?
Received 0 Votes
that was with wires hooked up. so i unhooked them. I get 120 for one black to ground. nothing for other 3 wires to ground. If i touch the live black to its corresponding white i get 0. If i touch the live black to the other white or black i get 30.
You will have to define the circuit.
Turn off the circuit breaker that controls that receptacle you are working on. See what else went off.
You should be able to plot the circuit based on what's not working from the panel to that receptacle location.
