Proper way to daisy chain an outlet from a timer
Old 02-27-13, 06:01 AM
Hi:
I currently have an outdoor GFCI outlet with a timer plugged into it that controls garden lights close to the house. Both outlet and timer are mounted to a fence about 2' above ground. We now want to sting lights to a back fence about 30' from that timer but controlled by the timer. We want all outdoor lighs to turn on and off at the same time. Please comment on my plan:
1. Mount an outdoor switch box with a pigtail that has a plug. This will plug into the timer.
2. Run outdoor conduit from this switch box back to the fence.
3. Mount a GFCI to the back fence, fed by the line coming through the conduit.
4. Plug the lights into this new GFCI.
Thanks!
Old 02-27-13, 06:22 AM
W
Received 51 Votes on 46 Posts
Receptacles
Why are you using two GFCI's in the same circuit?
Old 02-27-13, 06:56 AM
pcboss's Avatar
Received 148 Votes on 131 Posts
You cannot use flexible cords in place of building wiring so adding a pigtail to feed the downstream receptacle is a no-go.
Old 02-27-13, 07:40 AM
Thank you for your response. Can you recommend a proper solution?
Old 02-27-13, 08:15 AM
Justin Smith's Avatar
Received 1 Vote on 1 Post
How about a hardwired timer? Here's the one I use to control the contactors for my Christmas lights : Shop Utilitech Digital Commercial Or Residential Hardwired Timer at Lowes.com
You can also use a photocell.
Old 02-27-13, 09:26 AM
Angry
Thanks for the recommendation.
Old 02-27-13, 02:23 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
How do you have the existing lights connected to the timer?
Old 02-27-13, 03:39 PM
"How do you have the existing lights connected to the timer?"
Lights are connected to the transformer (not sure if that's the correct title) and the transformer plugged into a mounted outdoor timer.
Old 02-27-13, 04:17 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
You never mentioned this was low voltage wiring. That is a totally different thing. Are the new lights low voltage? Please clarify what you have and what you want to do. Do you want to add a line voltage receptacle some where in your yard from an existing receptacle and to plug a low voltage transformer into the new receptacle?
Why? A Malabu or other low voltage yard light transformer usually includes a timer.
