Reload this Page >
Adding outside fixture to garage. Found spare romex BUT....
Old 03-07-13, 04:15 PM
bobed2121's Avatar
when I meter it I only get 1.7v. I went up into the attic, traced it back to the closest outside fixture(I'll call "X"). "X" fixture works fine.
Let me diagram a bit. Up in my attic a romex from the outside lights switch comes into a small rectangular steel box. From that box there is a flex cable that goes into "X", they are right next to each other. From that same box another romex (the one with the 1.7v) runs to the spot where I want to add the new fixture. I can take a picture of the the "X" and adjacent connection if needed. I assume at this point something inside that box is either stepping down that last romex run or there is a loose neutral?
Any thoughts?
Old 03-07-13, 04:45 PM
ray2047's Avatar
If you used a digital multimeter your actual voltage reading is zero. You need to measure both from hot to ground and and hot to neutral. Could the cable you found be a switch loop?
Old 03-07-13, 05:07 PM
bobed2121's Avatar
Hang with me here. I found this romex up in my garage attic. It comes out of that box I referred to, and is stapled to some rafters and just left like that. I volt check it with my digital reader, when the outside light switch is off, and get 0v. Turn on the light switch and get a reading of 1.7v. this check is done at the end of this romex. I traced it back to that box I spoke of. That box is next to the good (working) outside light. I have yet to open the box to see what is going on in there.
I am not an electrician so I just assumed i'd have 120v at the end of that romex when switched on. Much like an outlet would read. "Switch loop" Don't know what that means.
Old 03-07-13, 05:46 PM
ray2047's Avatar
A switch loop consists of two wires that cary power from and back to a load.
Old 03-08-13, 05:48 AM
pcboss's Avatar
Check the connections in the junction box.
Your assumption about reading power with the switch on is correct if the connections are made properly.
