Reload this Page >
i'm putting a 240vac line in, and have several questions...
Old 03-08-13, 06:57 AM
R
I'm putting a 240vac line in, and have several questions:
1. Do I need to run conduit through the wall to the socket? I could terminate the conduit outside, or run it through the wall.
2. The socket will be an inside socket. I'm going to have to bore a hole to pass the wire through. I could cut a piece out of the wall, and put a socket holder in there. I could also put an external socket on the inside. Which of those would be better?
Old 03-08-13, 08:01 AM
pcboss's Avatar
Received 180 Upvotes on 158 Posts
The receptacle is going to need to be mounted to a box.
If you could provide more detail about your project more ideas can be given.
