Basic 110v to 220 v converter question
Received 0 Votes
Hey all !
I'm new to the forum and I had a quick question regarding buying a converter for converting 110v to 220v.
So I bought this mini component system from Europe, the Yamaha MCR 040. The back of the Yamaha shows the wattage as 30W and it works on 220v.
MCR-040 - HiFi Systems - Yamaha - UK and Ireland
Now I plan to take this back home to Boston and I was wondering which converter I should get. I cam across this converter from amazon :
Amazon.com: Seven Star 50 Watt Step Up Reverse International Converter: Electronics
Would something like that be enough or would I need to get something a little more powerful like
Amazon.com: Goldsource STU-100 Step Up/Down Voltage Transformer Converter - AC 110/220 V - 100 Watt: Electronics
I didn't know if the wattage just had to line up or is there something more to picking a converter.
Welcome to the forums! Members more savvy in European stuff will chime in, but in your case not only do you have to change the voltage from 120 which is common here in the states to 220 or 240, you will need to change the frequency from 50 Hertz, as we are on 60 here in the states. It isn't always cheaper to buy things from overseas and expect a simple voltage change to make them work. Hang in there for more comments from the other guys later on.
I didn't mean to rain on your parade, but, yeah, it may have cost less in the long run to order from a local outlet than bring something from overseas. I think it is retaliation for the Revolutionary War, or something like that
If the device runs off a separate low voltage power supply that is not built in but just plugs into the wall this is easy. You just use a US power supply with the same low voltage output. Same goes for if it has a battery connection. A US low voltage DC power supply can be used.
IF neither of the above applies then it is trickier. One way to do it is to use a power supply made for US market that converts 120 60hz AC to 12 volts DC then use a European DC to AC converter that converts 12 volts DC to 220 volts 50Hz AC.
However tha actual unit probably runs on low voltage DC so you could bypass the 220v 50Hz built in power supply and connect it directly to a low voltage DC power supply of the correct voltage. Of course with modern ICs and printed circuit boards that could be darn hard to figure out.
Or you could try a smoke test with a 120v to 220v transformer. If it doesn't burn up in a few hours you are probably good to go.
You could always wire in a UK receptacle for the radio on a 240V circuit.
In the UK you can also probably buy a travel adapter for using UK appliances in the US. That is probably the best option. Or you could run a 240 15 amp circuit with a 6-15 NEMA receptacle and change the plug on the stereo to a 6-15R.
Examle: US to UK Plug Travel Adaptor: Amazon.co.uk: Electronics
Received 0 Votes
In practice, difference between 230V and 240V may not pose much of a problem, but if the device requires 50Hz for circuit timing, then there will be a problem.
If I were in your shoes, I'd find out if there's an American version of this device, and if so, if a replacement power supply could be ordered for such an American unit. Trouble is, if something still takes timing off of the 50Hz AC current then that still might be a problem.
