Switching water heaters
Old 03-13-13, 11:18 AM
B
Hi Friends
I recently installed a tankless water heater only discover it does not suit us. It is too small and has 1/2 inch inlet and outlet so there is a considerable drop in pressure, especially during showers.
So I am going back to a regular WH.
Question: any problem connecting the WH to the 60 amp breaker and 6 gauge wire I installed for the tankless heater?
Hi
Old 03-13-13, 11:34 AM
Z
Received 298 Votes on 266 Posts
Yup, there is an issue with using a larger breaker than required. You can keep the 6ga wire, but the breaker needs to be swapped out with a double-pole 30A.
Old 03-13-13, 11:40 AM
Received 1,031 Votes on 990 Posts
Sorry to hear the tankless did not work out for you but that's a common theme, they're a lot better on paper than in the real world.
Old 03-14-13, 04:50 AM
With 1/2" inlet, outlet, and only a 60A breaker, it sounds like the OP has a point-of-use heater. It doesn't work because it's simply too small. That's not the heater's fault. We have a whole-house gas tankless and love it.
Old 03-14-13, 07:46 PM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
I have underlined the important part of the above post.
