[Stewart 1] A/C Generator Problem
Old 03-15-13, 09:46 AM
I have a second hand 5kva genset of Chinese manufacture. Unfortunately all details of the generator are long gone. My problem is that whilst the voltage is fine it's producing 150+hz frequency instead of the required 50hz. Can anybody please give me some idea what the problem might be.
Old 03-15-13, 10:13 AM
Wrong engine speed. Normal engine speeds are 4 pole/50Hz = 1500RPM, 4 pole/60Hz = 1800RPM, 2 pole/50Hz = 3000RPM, 2 pole/60Hz = 3600RPM. If the engine speed is not matched to the type of alternator, the frequency will be off.
Old 03-15-13, 10:37 AM
F
Received 35 Votes on 27 Posts
If your frequency meter is reading 150 Hz then the meter is at fault.
Old 03-15-13, 12:30 PM
D
Agree with Furd. It must be the meter is bad or your getting noise causing a bad reading. Try it with the generator driving a heavy load.
Old 03-16-13, 03:04 AM
Many thanks all. The meter is OK as reads correctly when measuring from our solar system. Has been suggested that it maybe the capacitor. Any comments?
Old 03-16-13, 05:40 AM
"Measuring from our solar system?" What does that mean?
Old 03-16-13, 07:20 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
What about testing is on a source from a commercial electric provider?
Old 03-16-13, 08:32 AM
D
Probably their solar panels.
Old 03-16-13, 08:43 AM
Received 1,113 Votes on 1,033 Posts
Measuring the output of the inverter on the solar panels.
Old 03-17-13, 04:34 AM
Thanks again. The tester has been tried on a commercial supply and we tested the output from the invertor on our solar system. Any thoughts please on whether the problem could be the caspacitor.
Old 03-17-13, 05:26 AM
R
The harmonics of the generator will cause funky readings on the meter.
The capacitor is there to excite the windings and weed out voltage surges.
Old 03-18-13, 10:36 PM
B
I had same problem
I tried everything but could never get it to work right. I finally had to call in a professional. They were able to get it going in about 10 minutes. Try *** ****
