Best breaker panel for the homeowner to do maintenance on
Received 0 Votes
Hey all,
I know that this could start a religious flamewar, but I would like opinions on the best breaker brand and type for the homeowner for changing out breakers.
I'm shopping for a subpanel somewhere in the 60-100A range for a garage. I'm familiar with Square-D QO series only.
If cost weren't terribly important, what would you choose?
Nash......really ? I could see Siemens and maybe CH over Square D .... but GE ?
GE makes some nice boxes.
I did list them in order of preference, BTW.
infernal flip-toggle-screw gizmos
You've got that right. I just love panel covers that take 3 people to install.
Actually, in my opinion, larger GE panelboards (like 400A, 800A, 1000A, 1200A) and switchboards have trims that appear to not be made for their own products. Everything fits sloppily and is very flimsy. The only reason GE still makes distribution equipment is they haven't been able to find a buyer.
We normally use ITE/Seimans panels plug in load centers and panelboards due to cost and qualtity. I do also like Square D QO and their Homeline brands, and Cuttler Hammer's CH line. Cuttler Hammer BRs are OK but seam kind of cheap. I do not like GE except for their panelboards that use bolt in breakers.
Not sure of the brand....probably Siemens, but they use a punched out tab at the top of the panel door to hang it by while you fiddle fart finding the screws. Makes for an easy door install.
I know they get slammed for aluminum buses and 2-pole tandems can easily be installed in the wrong spaces but but GE breakers are common as dirt almost anywhere and almost as cheap so if it is Sunday and two days before payday and you need a breaker GE is the choice. For me those were important factors when I replaced my Zinsco.
I really like the door-within-a-door fronts that Eaton, I think it is, is shipping with some panels now. Open door #1 and flip breakers. Open door#2 and swap out breakers. Nothing to set aside and reinstall, and you can close it up safe in a heartbeat.
I'm not a big fan of Square D. It goes back to when they had those infernal flip-toggle-screw gizmos to hold the deadfronts on. I know they haven't done that in years, but I still don't care for them.
#21
The QO hold the breakers in a bit better, OK, a lot better than the GE, but both work. Both use tin plated copper busses, which I value. The Homeline does not, a negative.
#22
Received 0 Votes
I'd go with Square D, because I've had some problems with Cutler Hammer. There was one time where I had a 90a Double Pole CH breaker flip right out of the panel when I switched it off. Square D works very well, and I like the way they put their neutral busses close to the main breaker in their MBPs. It makes top-feeding branch circuits so much easier, and it turns out a little nicer, IMHO.
