New Honeywell In Wall Timer - Neutral vs ground wire
Received 0 Votes
I had an Intermatic ST01 switch that worked well for three years, but started having problems so I replaced it with a Honeywell RPLS730B.
For the Intermatic you needed a ground wire, for the Honeywell you need a neutral wire. There is no neutral wire in the box that I am aware of so connected the Honeywell neutral wire to the ground wire in the box.
All seems to be working fine. This is new construction. Am I looking for problems here? Anything that could go wrong?
I meant it is a newer home - not new construction. Three years old.
