240V arc fault breaker?
Old 03-19-13, 06:30 PM
We plan to add 2 bedrooms with permanently installed electric beaeboard heaters. The code says 120V circuits have to be protected by arc fault breakers.
Our baseboard heaters will be using 240V. Do we have to use 240V arc fault breakers?
Old 03-19-13, 07:06 PM
ray2047's Avatar
National code does not require it but check with the local Authority Having Jurisdiction.
Old 03-20-13, 05:00 AM
pcboss's Avatar
The 240 volt units do not require AFCI protection under the NEC.
Old 03-20-13, 05:40 AM
Thank you for your prompt answers, I appreciate it.
