Electrical Panel Questions
Received 0 Votes
See pic. I have roughin plumbing near electrical panel. Would i be able to build an electrical closet with interior door for the panel and it be in the bathroom? Technically it would not be in bathroom since its in its own "room" for it.
If not what can I do? Thanks.
I have seen it done before and passed by an inspector, but I would recommend contacting your local inspector and run it by them. They may require the closet be 36" deep so that it is it's own "real" room
Panel
The area immediately in front of the panel cannot be blocked. Think of a space the size of a refrigerator. The pros will be along shortly with exact dimensions for the required clearance.
Received 0 Votes
So inspector I called said I could not have the panel in room within a room. Is that true? So can I have a wall with a door and through that door is a bathroom with a door and the panel be outside of bathroom? With the clearances.
