Marathon 1/2 hp electric motor
Received 0 Votes
Does anyone know how to change the rotation on this type motor?
There should be a wiring diagram on the motor or in on the junction cover.
Does the motor say reversible on it ?
Is there a model number on the motor you can post ?
.: Marathon Electric Motors - Motor Product Search :.
RVL48S17048A P
I cannot find that model number either. The link above is the Marathon motor locator. See if you match a motor number to it.
The reversing process.....if it is a reversible motor.....is just exchanging two wires. If all all else fails......take a picture of motor plate and post it...... or even a picture of inside the wiring compartment
RVL48S17048A P
Received 0 Votes
reversing the motor
after i take apart, the wires i will have to change ,will they have terminals or will i have to cut and solder. is there a danger of getting a short if i change the wrong wire.
They will probably not have terminals. You would cut and wirenut or solder and insulate.
Can you pull the power wire out of the junction box or post the colors of the wires you see in there ? (excluding your white, black and green)
The must be a private branded model number on that motor......it doesn't show up in the Marathon lineup.
Received 0 Votes
Picture of motor broken down
Here is a couple of pics, hope they will be of help. if i change the two wires that are soldered, it would be like turning the plug over.
Gray is one of the start winding colors. Blue is a definite run color.
That leaves red and yellow. If you have an ohmmeter or any kind of continuity checker.
Disconnect yellow wire from slide on terminal so that red and yellow don't touch.
check from .......... gray to red ................. gray to yellow
One of those combinations will show a short or meter movement and the other should show nothing.
Let me know what you find
Excellent job. Then we know the following:
Gray and red is the start winding and
blue and yellow is the run winding.
Put the yellow back on the same terminal it came off of.
You will need to reverse the gray and red wires.
Looks to be easily accomplished with a soldering iron.
