Installing 4 prong dryer outlet with old wiring.
As most of the times, I am the cause of my own problems.
Damaged the dryer circuit wiring while doing the plumbing. I don't have electrical dryer so there is no dryer hooked up to that outlet at the moment, so I am doing all this work for someone else's benefit and possibly for a piece of mind, assuming I still have it. Decided to use a junction box above the actual receptacle to run new wiring. Found out that I have only 3 (total) wires in that circuit. Old construction or whatever caused them to run a 220 with no ground. So now I have 1 black, 1 white, 1 (naked) wires all 10G. I am calling the third wire naked because I do not consider it a ground.
Can i run a 4 wire romex from my junction box and connect the wires as follows:
Old wire - new wire
BLK - BLK
WHT - RED
NAKED - WHT
Since there was no (real) ground in the old wiring connecting the ground from the junction box (please note it's completely different circuit) to new wiring's ground wire.
Thanks in advance!
Old wire - new wire
BLK - BLK
WHT - RED
NAKED - WHT
Thanks in advance!
If by naked you mean a bare copper wire, as in 10-2 with ground romex (NM cable), that was never legal anyway. The old wiring should probably have been 1 Blk, 1 Red and 1 Wht. My opinion is no, you cannot connect a 4-wire receptacle to the old circuit. You need to run a new circuit with 10-3 w/G NM B cable
Thank you
Thank you for a speedy reply.
I am considering just disconnecting the wires at the circuit breaker and drywalling the outlet. I am not using it, most people prefer the gas dryer anyway because of savings compare to the electric one. I see no point for me to run a completely new homerun from the opposite side of the house.
Not sure if I can drywall the outlet or just put a blank over it though.
Thanks again.
Thanks again.
