Short circuit in 12/2 wire
Old 04-24-13, 07:56 PM
I have a dead short in a 12/2 romex cable buried under ground. I have been able to isolate the affected cable. Can I measure the resistance in the wire to calculate where the short is. What I mean is once I measure the resistance can I measure off in feet to where the short is.
Old 04-24-13, 08:01 PM
ray2047's Avatar
I have moved your post to its own thread. You had posted to someone else's thread and that can cause confusion.
No, a resistance reading won't help. Is this UF cable or NM-b (Romex) cable?
Old 04-24-13, 08:56 PM
Nashkat1's Avatar
No, but why do you want to know that? Don't you just need to replace the full run?
Old 04-25-13, 04:46 AM
pcboss's Avatar
If this is UF cable an underground splice kit can be used. If it is NM cable the entire run needs to be replaced.
Old 04-25-13, 12:06 PM
You can't measure it with a multimeter but this could be done with a time domain reflectometer. Some electricians may have one. It will find the break. If this is a short run I'd just replace it.
