Similar scenario, another [LV] transformer question
Old 04-29-13, 10:39 AM
Lightbulb Similar scenario, another [LV] transformer question
Separted from: http://www.doityourself.com/forum/el...er-inside.html
The house I live in has a 100 watt transformer mounted in attached garage, and 12awg wiring runs outside to low voltage landscape lighting. Wiring was damaged so I am looking to replace.
I found transformer manual and it notes it can be used for 1) spa underwater lights indoors or outdoors, and 2) landscape lighting outdoors only. Why can the former be installed indoors while the latter can not?
Thanks
Old 04-29-13, 10:56 AM
pcboss's Avatar
It may be just the way the manufacturer paid to have the item tested for its listing. However, that does not relieve you of follwing the instructions.
Old 04-29-13, 11:47 AM
Nashkat1's Avatar
Welcome to the forums!
Do you think the manufacturer might be saying that the transformer can be used to power the lights for either an indoor or an outdoor spa, but only for outdoor landscape lighting?
Old 04-29-13, 11:57 AM
ray2047's Avatar
Buster I have moved your post to its own thread. It gets confusing when you piggyback on someone else's. Who know who is answering what to whom.
Old 04-29-13, 12:18 PM
Nashkat1, good point. Here's the wording directly from the manual. I have the PX100 model. Which do you think it means - that I can't install the transformer indoors for use for landscape lights, or I can't install landscape lights indoors and use this transformer! And if it's the latter, is there any restriction or concern mounting this transformer indoors in my garage?
INTERMATIC
PX SERIES LOW VOLTAGE LANDSCAPE AND SWIMMING
POOL/SPA LIGHT TRANSFORMERS
INSTALLATION OPERATION & SERVICE MANUAL
Model: PX100 and PX100S - 100 Watt Transformers
INPUT: 120 V.AC, OUTPUT: 12 V.AC or 13 V.AC
Model: PX300 and PX300S - 300 Watt Transformers
INPUT: 120 V.AC, OUTPUT: 12 V.AC, 13 V.AC or 14 V.AC
Suitable for direct connection to underwater lights and for Indoor/Outdoor installations except in CANADA - Low Voltage Landscape Lighting installation - Outdoor only.
These Safety Transformers are specifically designed to
supply 12 volts to pool/spa lights, submersible fixtures
and outdoor garden lights. A grounded shield between
the primary and secondary windings assures safe
operation and the built-in circuit protection will disconnect
power to the transformer in case of defect or overload.
These transformers are suitable for direct connection to
underwater Pool and Spa lights.
