Baseboard Thermostat Wattage Rating
Old 05-02-13, 05:18 AM
I am installing electric baseboard heat in a new room addition, (one room upstairs, one down). I want a programmable thermostat in each room.
Downstairs I have baseboard units that total 3600 W, on a 20A 240v circuit. The line voltage thermostat that I want to use is rated for 3600 W, 15A, (3600W / 240v = 15A). It's my understanding that I can install this 15A thermostat into the 20A circuit since the total load on the circuit is known and limited to 3600 W (15A).
Is that correct?
Upstairs my question is similar. The baseboards total 5500 W, on a 30A 240v circuit. Since there is no programmable thermostat of that capacity, I am using a 23A relay switch with built in 24v transformer, which will be controlled by a thermostat. Same question as downstairs. The relay is rated for 23A, 5520 W, but is on the 30A circuit. Is this OK since I know that the total load on the circuit is 5500W?
Thanks in advance to anyone who can answer.
RZ
Old 05-02-13, 06:27 AM
Tolyn Ironhand's Avatar
Welcome to the forums!
You are correct. The thermostat/relay need to be rated for the connected load, not the rating of the circuit breaker.
Old 05-02-13, 02:50 PM
Since this a space heating circuit the relay must be rated for 23 amperes continuously, meaning more than three hours without a break, in order to meet code requirements. If the relay is rated for use in heating circuits it probably is rated for continuous service but you might want to check to be sure.
Old 05-02-13, 04:00 PM
Thanks for confirming this.
RZ
Old 05-02-13, 04:04 PM
Yes, this Aube relay, RT850T, is made specifically for controlling heating circuits. Thanks for the input.
RZ
