my pneumatic selinoid valve not switching
Old 05-03-13, 08:24 AM
Smile my pneumatic selinoid valve not switching
hello,
i need help on my newly ordered pneumatic solenoid valve, i am trying to test it but it does not seem to switch when i apply the 12 volt. i can hear the sound of some kind of relay but the coil is probably not energized. what am i doing wrong ? the valve is from wic it is rated for 12 volt. my intention is to use a darlington transistor to drive it, but i can not go to that stage before i make sure that it work in its basic configuration by directly energizing it
regards
mohammed
Old 05-03-13, 08:47 AM
ray2047's Avatar
Is this 12 volt dc valve? What amperage? Does your power supply match in voltage and equal or exceed the required amperage. If valve is DC is it a DC power supply?
Old 05-03-13, 12:20 PM
yes it is a 12 v DC valve. i just hooked it directly to a 12v battery!
Old 05-03-13, 12:31 PM
ray2047's Avatar
A car battery or something smaller? Have you tried blowing through it while energized?
What is "wic". I assume you didn't get this from the nutrition program for Women, Infants, and Children.
Old 05-03-13, 11:13 PM
yes it is a bit smaller 12 v battery than that of a car, i triedw to brow through it hoping the path will change to the other port but it did not. WIC is the brand or the manufacture.
pneumatic directional control solenoid valve, 3 way Solenoid Valve, air valve
Old 05-03-13, 11:21 PM
ray2047's Avatar
The specs seem to indicate a minimum pressure of 27PSI so I'm not sure you can test by blowing.
Old 05-04-13, 12:02 AM
i think there is what i am making the mistake, i am not considering the pressure parameter and my lungs are not that powerful
thank you for the insight.
