Can I have GFCI Outlets on same circut as normal outlets? 12/2
Received 0 Votes
Hi everyone, I am looking a few books and they all show samples of circuits but never tell or show if you can mix outlet types.
I have a circuit running to 2 bedrooms for my power outlets. The are on 12/2 and a total of 6 outlets. I wanted to add 2 GFCI outlets for the deck outside and wanted to know if it was ok to add those outlets to this circuit since I can still add 4 more outlets?
Can't seem to find sample diagrams.
...since I can still add 4 more outlets?
As I recall the code DOES specify that there be at least two receptacles outside, one in the front of the house and one in the back. These must be 20 ampere circuits and they must be GFCI protected along with having "in-use" covers (bubble covers) installed. These receptacles may be fed from any circuit that is not dedicated such as bathroom or kitchen counter receptacle circuits.
So, yes, you may install the outside receptacle on the proposed circuit.
This would be wired the same as regular receptacles inside the house. If the one receptacle outside is downstream from the GFI it can be a regular receptacle also. It would be wired off the LOAD terminals of the GFI.
The GFI needs to be marked WR for weather resistant.
Depending on your code cycle you are on it could require AFCI protection for the bedrooom and tamper resisstant devices.
