Two GFCIs on same line for hot tub
My hot tub is wired with the proper 240v 50amp gfci breaker located near the hot tub. But I discovered that the 240v 50 amp breaker that feeds the hot tub at the main breaker board in the basement is also gfci. Is there harm in there being two gfci's on the same line?
Welcome to the forums!
When one GFCI device is downstream of another one, it can result in nuisance tripping. How long has the feed and protection for your hot tub been wired this way? Have you had any instances of either of the GFCIs tripping for no apparent reason?
There only needs to be one source of GFI protection for the tub. It can be in either location. Given the cost of a 2 pole GFI this has me surprised that there are two.
I have not experienced any nuisance trips. It's been that way since the hot tub was installed last fall. The previous installation of an older hot tub had a shut off breaker out by the hot tub, but it was not gfci-- the only gfci was the one on the main board. At that time the installer put the proper gfci breaker out by the hot tub. But I just discovered that he left the original gfci breaker in place on the main board.
FWIW, I prefer protecting dedicated GFCI circuits in the panel, so that the whole run is protected.
