Reload this Page >
Code compliant method of repairing broken insulation inside a J/outlet box
Old 05-06-13, 09:37 PM
Hi all,
Unfortunately, drama with my contractor continues... While I was inspecting his work, I found--quite horrifyingly--that in some outlet/switch boxes, the insulation of the hot/neutral wires is sliced/broken. When he was cutting the romex, he must have used a utility knife, did a sloppy job, and cut right into the inner wires.
In some places, only the outermost (transparent) sleeve is cut/compromised. In other places, however, the whole insulation is sliced such that bare copper is showing (on a hot wire at that!).
Putting aside my anger/disbelief/frustration for the moment... is there a code compliant way to fix this without rewiring the entire segment? I'm seriously contemplating firing my contractor finishing the work myself.
I read on some other forum that electrical tape is allowable, provided that the voltage/temperature rating is appropriate. But is it? I searched through the entire 2008 NEC and the word "tape" only showed up 64 times; and none refer to this situation. If you have any suggestion on which section to look, that would be greatly appreciated too.
Thanks!
Old 05-06-13, 09:40 PM
ray2047's Avatar
Heat shrink tubing if you can't get him to do it the right way on his dime by replacing the damaged wire.
Old 05-06-13, 09:41 PM
It takes a little care when stripping NM cable. I've used a knife forever and have only nicked a few wires.
You can use heat shrink tubing to repair the insulation.
Ray.....you're getting pretty quick for an old guy
Old 05-06-13, 09:46 PM
Thanks guys! Much appreciated. You guys are the best =)
Old 05-07-13, 04:24 AM
pcboss's Avatar
Heat shrink is preferable over tape. However, I would push strongly for new cables. There are strippers made to do this task that do not damage the conductors. They are also faster than the knife method.
