Weird GFCI problem
Old 05-08-13, 01:51 AM
Weird GFCI problem
I am running some underground conduit from a subpanel to my kitchen. The conduit goes through a French drain and to spare myself digging through two feet of stones, I buried the conduit at 12" (NEC 300.5 Column 4) and put GFCIs at the home run end of the circuit.
Here's the part I don't understand. The wire in the kitchen is hot. A multitest on the ground and the hot wires shows the same voltage as hot and neutral. (So it's grounded.)
Polarity is not reversed. But when I plug a radio into the kitchen receptacle, the GFCI trips and will not reset. I have swapped out the GFCI with a different one and it still trips.
Any help would be greatly appreciated. I am stumped. Thanks!
Old 05-08-13, 02:17 AM
ray2047's Avatar
What about a lamp? Maybe it's the radio.
Old 05-08-13, 11:08 AM
Thanks Ray. As ever, a giant DUH. Before the inspector dinged me for having an "external conduit" that was "architecturally unacceptable" I had a straight shot of four pairs from the subpanel to the kitchen. Which neutral I used didn't matter. All ran back to the subpanel.
Now that I have interposed a bank of GFCIs,the specific neutral leaving a specific GFCI device very much does matter.I had a neutral running back to a different GFCI. So I did get current, it was indeed grounded, but when I introduced a load (e.g., a turned-off light) into the receptacle it tripped. The neutral was going back to a different GFCI.
Duh.
Before you say "hire an electrician" I d i d hire an electrician. He's the one who put the conduit outside the house. Ahem.
I am lazy because accessing the jbox to the kitchen requires going through a nasty crawlspace. Just took six hours out of my life. that's all.
A mind f**t.
THanks for your help, nonetheless.
Old 05-08-13, 05:51 PM
CasualJoe's Avatar
That is obviously a local code, the NEC has no "architechurally unacceptable" clauses.
Old 05-08-13, 07:51 PM
pcboss's Avatar
I hope you did not run loose conductors without a conduit. There is little chance to confuse cables neutrals and hots between cables.
Old 05-08-13, 08:24 PM
Nashkat1's Avatar
It's run in conduit .
