New Bathroom Circuit
Old 05-11-13, 05:39 PM
I am installing a new circuit in a bathroom for a floor and towel warmer. The two warmers draw less than 8 amps combined.
Should I use a 1 - 15 amp breaker (GFCI/AFCI) for both warmers with #12 or #14 wire?
Old 05-11-13, 05:49 PM
Tolyn Ironhand's Avatar
Any receptacle in a bathroom is required to have GFCI protection.
Any electric in-floor heat is also required to have GFCI protection.
15 amp breakers require #14 wire. 20 amp breakers require #12 wire.
Old 05-11-13, 07:00 PM
pcboss's Avatar
Are both the towel warmer and the floor heat 120 or 240 volt?
Old 05-11-13, 08:03 PM
CasualJoe's Avatar
What.......No heated toilet seat??
Old 05-25-13, 07:41 PM
The towel warmer and floor heater are both 120 volt!
Old 05-25-13, 08:22 PM
Nashkat1's Avatar
One 120V 15A circuit for both. GFCI circuit breaker. AFCI is not required on this circuit. 14 AWG wire (14-2/G cable).
Old 05-26-13, 10:57 AM
Thanks! Is it still okay to create 2 seperate 15A circuits from a 14-3/G cable?
Old 05-26-13, 11:06 AM
Yes. Be sure to use a two pole 15 amp breaker.
Old 05-26-13, 03:21 PM
Thanks for your help and advice!
Old 05-26-13, 09:20 PM
Nashkat1's Avatar
If your question is "Is it still okay to use 14-2/G cable to run a multiwire branch circuit with two hot wires that share a neutral?", then yes, it is. The better practice is to use two adjacent single-pole breakers to protect the two circuits and join the breaker handles with a handle tie, rather than using a 2-pole breaker. Using two breakers and a handle tie allows each circuit to trip on its own while still requiring that both will be turned off for servicing.
Is this question related to this project or a different one? Earlier you said
and I replied
Is there something I misunderstood?
Old 05-27-13, 04:30 AM
chandler's Avatar
Check your controls for these two items. I just installed floor heating and it came with a built in GFCI, so none was needed at the panel. You don't want two GFCI's in the same mix.
