Converting 12dc or 24vdc to 18vac? For ptz camera on boat
Old 05-13-13, 07:10 PM
Question Converting 12dc or 24vdc to 18vac? For ptz camera on boat
What solutions other than a big 12vdc inverter to ac transformer is there? I may get a high dollar ptz camera for a fair price but its 18vAC and i do not have nor want to purchuse the expensive power supply. $800 heh. Id rather build one or fidn a cheaper solution. We have 3 large marine batteries on board, but not sure how to convert to 18vac.. thsi si the camera user guide, it is the Bosch MIC400 http://stna.resource.bosch.com/docum...2303476491.pdf
Old 05-13-13, 09:13 PM
Nick D.'s Avatar
The OP is asking to convert DC to AC.
I'll be blunt, there is NO cheap way to make AC that is satisfactory for electronics. You can get a cheap inverter, but they will output a square or modified sine wave, neither of which are desirable substitutes for "AC".
A good inverter that produces a satisfactory or "close enough" sine will cost a couple hundred dollars.
Last edited by ray2047; 05-13-13 at 10:00 PM. Reason: Remove quote from deleted post.
Old 05-13-13, 09:28 PM
how about converting the electronics to accept dc?
what if I modified the pcb to accept dc somehow? i don't know what actually uses the ac other than maybe a heater? what to do what to do, i may end up getting the camera for around #200 so its a hard deal not to take.. they do make 12vdc models, im just unsure of what the difference is. guess ill post back if i get my hands on it and maybe someone can help.
Old 05-13-13, 09:47 PM
I work with Bosch cameras but not that one. The camera has the ability to work with a 12VDC supply. I see they make a custom power supply to work with the camera. Since the price of that supply is over 300.00 I have to assume that it's more than just a simple power supply.
I am concerned though......when I was reading the specs I see bi-phase mentioned. That's the protocol Bosch uses to control the PTZ functions of the camera. You may need a bi-phase controller to move the camera.
Knowing Bosch......this may become an expensive camera setup.
Old 05-13-13, 09:54 PM
Thanks for that info, very helpful. I would be using it as the mast camera ill have to look into the bi-phase controller. but a $5000+ camera for $200.. i just cant say no as its hard to find a decent camera that will hopefully last up there and have all the options and i hate to order from overseas so its very tempting for the price of it as for now. I do appreciate all the feedback! Thanks!
Old 05-13-13, 10:08 PM
Keep in touch.....I'll work with you.
