Sub Panel Diagrams
Sub Panel Diagrams
The term sub panel does not appear in the NEC but for convenience we use it to refer to any panel other than the panel containing the first OCPD (Over Current Protection Device). Below are three of the most common for subpanels not in the same structure and one for a subpanel in the same structure. The first four diagrams are based on 2008 NEC code. The fifth diagram is based on NEC code before the 2008 cycle assuming no other metallic pathways. It is usually grandfathered unless major changes are made. What is a major change is determined by the Authority Having Jurisdiction (AHJ).
120 volt 30 amp RV panel using 240 volt Main Lug panel.
TRANSFER SWITCH With subpanel connected to first OCPD and inlet.
Received 0 Votes
main panel to sub panel same structure
Hi
I was wandering why the diagram on main panel & sub panel on same structure
has no ground rod & marked no ground rod? it is the 4th diagram down....
