Load Center Generator Interlock
Received 0 Votes
Hello,
I'm trying to find a Load Center Generator Interlock for my Siemens Load Center G2020MB1100CU.
Does anyone know of an alternative to the $150. kits sold by Interlock?
I need their K-1510 kit.
Thanks,
Stig
P.S. Will the Siemens ECSBPK04 interlock kit fit my load center?
Additional information:
ECSBPK04
For use on Ultimate and Rock Solid
load centers 125 amp and lower to
connect the main breaker to a 2-pole
circuit breaker.
Thanks,
Stig
ECSBPK04
circuit breaker.
Welcome to the forums!
$150 would be cheap for a method of safely switching the power feed from the power company to a backup generator, if it worked and was U.L. listed for the application.
Why are you trying to install an interlock instead of a transfer switch or a transfer panel? How did you determine that the Interlock K-1510 is the one you need?
Most importantly, does your local jurisdiction permit the installation of aftermarket interlock kits?
