outlet burned but breaker did not trip
Old 05-21-13, 04:53 PM
I baught a 20A breaker, installed it in an empty slot in the breaker panel. Then I ran a 12-2 cable to an outlet installed in an attached garage. I was running a heater then about 2 hours or so, it went out and the wires in the outlet had burned! Why? Wouldn't the breaker had tripped first? Thanks in advance for any insight!
Old 05-21-13, 04:57 PM
ray2047's Avatar
How many amps does the heater draw. Is the heater 120 volts. What brand panel do you have? What make and model number breaker did you buy?
Old 05-21-13, 06:33 PM
Wow.....I see Ray has a few questions.
If the wiring burned at the receptacle then it was improperly attached. Either the screws weren't tightened or the #12 wire was forced into the #14 only stabs on the back of the receptacle.
Old 05-21-13, 07:17 PM
ray2047's Avatar
Oh gee, I'm looking for zebras and here PJ goes and points out they're horses. Well I did hear hoof beats anyway.
Old 05-21-13, 07:49 PM
CasualJoe's Avatar
Breakers trip because of overload or a short circuit, you had neither. You had a loose connection that got hot and burned the wires and that will not trip a breaker till you have a fire that eventually causes a short circuit.
Old 05-22-13, 12:44 PM
I assume they were either backstabbed or if attached to the screw terminals, not enough insulation was removed.
Old 05-22-13, 06:53 PM
Thanks Ray......you just made my day.
