AFCI tripping
AFCI tripping
Nearly all my work is done on homes without CO, so no final electrical is connected. We work off temporary poles. Retrofitting a house with shelves tosay, one of my guys plugged in my Ridgid double miter saw into a receptacle and triggered it. Ran for one second and tripped the breaker. He called me in to check it out. It was on a bedroom circuit AFCI. I deducted that it was picking up the arcing of my saw's motor and shutting down. Removed it to the washing machine receptacle and all was well. Any thoughts on that?
Makes perfect sense to me.
I've now seen all kinds of devices trip an AFCI breaker. Right down to laser printers due to their inrush current when the heater first fires up.
Do you know what generation and manufacturer these were?
It depends on those two variables how good or badly the AFCI will perform. Current AFCIs from a reputable maker like Seimens do not respond to series arcs, such as found in brush motors.
Originally Posted by Andrew Mills
Anything with a motor will set them off because of the arcing.
It's a new house, but I didn't even note the brand of panel. I was just curious if it was commonplace, which apparently it should not be with current types of AFCI's. One thing popped into my head.....when you let go of the trigger, a half wave rectifier turns the spinning motor into a generator in reverse for a blade brake, until the blade stops. Of course it could have been a bad breaker, too, who knows?
I can't see why such a thing would trip an AFCI, though... defective or not.
It may not be for this particular tool, as I have not taken it apart. I have repaired several of my radial arm/cut off and miter saws in the past that the blade brake failed on. Invariably I would have to go to Radio Shack and purchase a half wave rectifier and replace it. Not an assumption in general. As far as being an "implied" feature, probably not, but that's how it works. As soon as you deprive the spinning motor of current, it ceases using power and begins createing power in reverse as a generator. Thus the half wave rectifier. It falls off as the motor comes to rest.
In all seriousness, they never sold a half wave rectifier as far as I know. A couple of high power diodes, sure.
Chandler, in your saw, what happens to that power generated? Does it have a big resistor in there? I'm just curious because that brake sounds cool. I'm resisting the urge to wonder why it even needs a rectifier at all. Too late. No seriously I've never taken apart my own power tools.
The fun thing at Radio Shack is too look up the Radio Shack model number on line first then when they say there is no such thing whip out the RS number.
I knew a TV repairman who back in the days of vacuum tubes sometimes would run out of a particular tube on a weekend and wasn't near a 7-11 where he could get RCA tubes but near a Radio Shack which carried their own brand of tubes. He'd buy four of the tube he needed. Try each, leave the one that worked in place and throw away the other three.
P.S. Yes, I really meant 7-11 the convenience store. Not only did they have a tube tester and sell tubes they rented TVs by the day.
whip out
I could be wrong.
In my old city (Des Moines) there was _one_ store (out of like 10) that still sold simple things like resistors. It was right next to an urban college. You know, where nobody has any money. One wonders what they were thinking. The college wasn't the type for engineers. *cough* *liberals* *cough*
That was probably 5/10-15 years ago, I'd be curious what the status is of everyone's Radio Shacks out there. Perhaps that should be the subject of a diff thread.
For series-wound universal motors (most power tools), the braking current is half-wave. In AC induction motors, braking current is DC. The cool thing about AC motor braking is that it only takes a relatively small amount of DC current. Just 12v at a few hundred mA will stop a small unloaded motor in a split second.
What year was this?
Back in the '50s and '60s growing up in the south all 7-11s rented TVs as far as I know. Fun fact: No AC back then. The hole front of the store was garage doors that were left up during business hours in the summer. Fun history fact: The one I remember moved across the street to Miller county (Arkansas) so it could sell beer since Bowie county (Texas) was dry. I always wondered if it moved back when Texas started the lottery.
I remember the garage doors across the front, but I don't remember the tubes for sale or the rental TVs. Maybe it wasn't all 7-11s. OTOH, the first time I remember encountering 7-11s was when we moved to the Big City in '55. I think they started down your way and spread out to the rest of us.
Tube testers?? Sure, at every convenience store. They also had some of the more common ones in stock behind the counter. Remember that well. Heck, I remember when Waffle House CEO decided to give all his employees Christmas off. Only one problem...Waffle Houses were built without locks. They never closed, so why have locks. Had to install locksets to close the stores. Not sure how widespread that was, but in Atlanta it was common.
I do remember tube testers in some stores, now that you say it that way, Larry. Something about that phrase triggered it. My memory, now that I'm in touch with it, includes some stock out in the open - maybe on wire shelves below the tester.
I don't remember what store or stores though. The Feed and Seed, or the dime store?
#23
Donna Reed housewife testing a tube like it's a weekly occurrence.
And then Motorola under the Quasar name came out with the "works in a drawer" It was an early solid state color TV where the chassis slid out from the front and the homeowner could replace one of ten solid state modules depending on the problem. (and they did have problems)
I could go on all night.
To get back on topic... I have a particular customer that uses large laser printers in his bedrooms. He routinely trips under one year old Square D QO AFCI breakers in two of the bedrooms. I have replaced them both and they still trip.
#25
Ray, trips down memory lane are never off topic, to me. That's exactly what I remember at Sim's Pharmacy when I was younger....much younger
#26
Back to the issue at hand.
First thing I would do is to try another high draw tool like a shop vac, or another saw, and see if that will trip the AFCI. Also, try the saw on another receptacle on the same circuit and see if that will trip it. There might be a slightly loose connection someplace the does not arc until a good sized load is put on the circuit.
We did a new house that a circuit was fine until a shop vac was run on it. Then it would trip right away. Turned out the HVAC guy used a framing nailer to nail on his returns with 3" nails. Not good for NM cables.
#27
I'll check connections when I go back to make sure they are solid. It is apparently a bedroom circuit with this outside GFCI receptacle on it. Only 4 receptacles, so it should be easy to check.
