direct wiring a programmable motor
Old 05-27-13, 10:54 AM
T
I have a GE programmable motor in a squirrel cage housing that I want to use as an air mover in my garage. I don't need all the programmable stuff that in came with. I would like to wire it up direct to an 110 outlet with an inline switch. I need to know which of the 5 wires to the motor I need to use. there is a black, blue, red, and 2 brown wires going to the motor. The mfrs # for the motor is HD44AE115. Any help would be appreciated.
Old 05-27-13, 08:26 PM
P
Temporarily Suspended
Are there any markings where the wires connect? Remove the cover if needed. You don't have to use the programming, just because it's there.
Old 05-28-13, 03:36 AM
Tolyn Ironhand's Avatar
Received 710 Upvotes on 603 Posts
Did this come out of a furnace? If so, do you know what model?
Does it look like this: Carrier HD44AE115 Programmable Motor 1 2 HP RPM 0 1300 115V | eBay
Old 05-28-13, 06:27 AM
T
removed control box
I have removed the control box and I am left with the five wires I mentioned coming out of the motor itself. I tried hooking up 119 volts to the red, black, and blue wires in different configurations. The motor turns but no where near 1300 RPMs. Hooking up the brown wires seems to have no effect. The motor does have the markings on it that you mentioned in your reply.
Old 05-28-13, 07:22 AM
Received 3,485 Upvotes on 3,128 Posts
I couldn't find any real detailed info on the control box (variable speed module) but I have a feeling the motor may run on three phase. That board does some kind of phase conversion which you won't be able to duplicate.
Supplying 120vac to the motor and a variable AC voltage from 5-24vac to the control section may work since that is part of servicing. I just couldn't find the exact location to connect the signal voltage.
The proprietary design is well guarded.
GE ECM Serviicing
Old 06-30-13, 04:14 PM
H
If you could find a white wire you would be all set.
Like put a capacitor on the 2 brown and white neutral and color for speed choice. Sounds like it's a 3 speed.
My bad. I looked at the ebay display and it has a good data tag.
No doubt over this idiots(me) Pay grade.
