Weed Wacker Charger & No Power
Old 05-29-13, 06:22 PM
After recharging my weedwacker I accidentally left the charger plugged in by itself overnight in my shed. Now the shed lights, one inside outlet, & an outside outlet for the pool filter don't work. Checked the panel & circuit breaker tripped. However unable to reset breaker.
How can I determine what's wrong & fix it?
Also, was this caused by leaving the charger plugged in?
Thanks,
Jake
Old 05-29-13, 06:47 PM
core's Avatar
Is the wiring in your shed exposed? Is it possible a garden implement of destruction damaged a cable? That should be easy to check with a visual inspection.
I would start by opening the receptacle where that charger was plugged in. Check for any loose/exposed wires or anything melted, etc. I highly doubt an idle charger would draw enough current to cause problems overnight even if the plug was hanging halfway out of the wall.
Is this breaker a GFCI breaker by chance? Did you have any storms the night this happened? Where does this circuit get its power from, a subpanel in the shed or is this breaker you mention in your house and now the entire shed is without power?
Old 05-29-13, 07:49 PM
Nashkat1's Avatar
Welcome to the forums!
Did you turn the breaker fully off before trying to turn it on?
