Post light with sensor alternates on and off in daylight
Old 06-02-13, 05:48 PM
Question Post light with sensor alternates on and off in daylight
Hi everyone, I'm new to this forum. My husband and I have a strange issue that has us both scratching our heads...
We have a post light out front that wasn't working since the day we bought our house. We replaced the lamp, light bulb, and light sensor. Now in daylight it alternates on and off every 20 seconds or so, and in darkness it stays on. Could the sensor be faulty to cause it to alternate when it should just be off? I just hope we didn't mis-wire it or something!
Any feedback is appreciated!
Old 06-02-13, 05:51 PM
ray2047's Avatar
Did you use an incandescent bulb? If your sensor has no neutral a CFL bulb will blink like that.
Old 06-02-13, 06:01 PM
I was thinking along those lines at first too. We tried a CFL (60 watt, 900 lumens) and an incandescent (100 watt). It blinks with both bulbs.
Old 06-02-13, 06:20 PM
Actually I should clarify: Our sensor has a white wire (which I believe is the neutral). Here's a picture of the wiring (sorry it's blurry). I'm starting to believe we switched the red and black wires coming out of the sensor. http://i.imgur.com/aN0g1gO.jpg
Old 06-02-13, 06:21 PM
Did you use an actual lamp post photo cell....the one that mounts thru the pole ?
Those usually have a neutral connection on them. It sounds like you may have a defective photo cell.
Old 06-02-13, 07:27 PM
ray2047's Avatar
While not written in stone most times black is power in and red is power out.
Old 06-02-13, 07:44 PM
Indeed the red and black wires were switched. The sad thing is we had wired it exactly the same as the old one was. Maybe that's why it was burnt out... heh...
Old 06-02-13, 08:32 PM
ray2047's Avatar
Glad you got it. Thanks for letting us know
