Minimum wire guage
Old 06-03-13, 07:29 AM
Minimum wire guage
I am running a service to my small workshop. I plan on one 30 amp circuit, RV hookup outside the workshop, and 2 20 amp circuits inside. question is, what max load breaker should I use for the small panel I will be putting in the work shop and what size wire should I use to run from the main house panel to the small breaker box I will be installing in the work shop? run is approximately 75 feet from the house to the workshop.
Old 06-03-13, 07:39 AM
ray2047's Avatar
Depends on the loads in the work shop and how heavy the RV receptacle will be loaded but it sounds like 60 amps using #6 THWN should be enough.
Old 06-04-13, 07:45 AM
Thanks! Load on the RV receptacle will be light for the most part as it will be hooked up during winter just to keep the fridge running.
