Tandem Breaker as a replacement for a single breaker
Old 06-05-13, 09:52 AM
I ran some wire to my shed and wired one outlet, but now I need to connect this to the power in my house. Currently my breaker box is full, and there are 5 tandem breakers already in it. My idea was to replace one of the other single breakers with a tandem one and wire my new circuit into it.
The box is a Square D QOC 20MW 225 with 200 amp service.
Is this the correct way to go about this?
thanks!
Old 06-05-13, 12:25 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
Welcome to the forums!
Since two tandem breakers fit in each full-height breaker position, you should have an even number of tandem breakers in your panel. Do you mean piggyback breakers?
Some terminology:
  • A standard full-height single-pole circuit breaker is 1" tall, has one terminal and one handle, and can protect one 120V circuit.
  • A tandem breaker is 1/2" high - half the width of a full-height breaker - and protects one 120V circuit.
  • A piggyback breaker is 1" tall - full height - and has two terminals and two handles. It can protect two 120V circuits.
  • A tandem piggyback breaker is 1/2" tall, has two terminals ans two handles, and can protect two 120V circuits.
If your plan is to remove either a full-height or a half-height (tandem) single-circuit breaker, replace it with a piggyback breaker, and use one half of the new breaker to supply the new circuit and the other to supply the circuit that was connected to the breaker you remove, that may work.
What type of wire or cable did you run to your shed, and how did you run it? What does the label on the inside of the door of your panel tell you about allowable breakers and positions?
A link to the specs for your panel would help us. A couple of pictures - one of the panel label and one of the breaker array, might also help. See How To Include Pictures.
Old 06-05-13, 01:32 PM
Tandems are not single handle. A single handle 1/2" breaker is simply called half-height, and a 1/2" breaker with two handles is a half-height tandem. Any breaker that has two handles on the same leg is a tandem. You could use tandem and piggyback breaker interchangeably in a sentence - they are not two different things.
He is saying he has five breakers that each have two handles. If it's a CTL panel that hasn't been overloaded, there should be (at least) one more space than can be swapped for a tandem.
Edit: That catalog number is just for the cover. There should be another longer number which will be the number for the 'guts'.
Old 06-05-13, 02:57 PM
Nashkat1's Avatar
That may be true in your area and in your experience. What I posted is true in my area and my experience. It seems there's not consensus on this.
Regardless, this should help us get some clarity.
And also regardless, we do need the # of the panel itself (the part inside)!
Old 06-05-13, 03:18 PM
F
Received 36 Votes on 28 Posts
Twin, duplex, piggy-back, half-size...I've heard/read all the descriptors and I don't think that there is a single universally recognized definition.
Old 06-05-13, 03:23 PM
Nashkat1's Avatar
Yep. I just hope we haven't confused the OP too much!
Old 06-05-13, 11:45 PM
Be that as it may, the word 'tandem' by definition implies 'two on one'. Is a tandem bicycle a half-sized one-person bicycle? No, it's a single bicycle that fits two people. So a 'tandem breaker' - by definition - has two handles on one device. And if you google "tandem breaker" and flip to images, you will not find a single picture of a single-handled breaker of any size.
Yes, 'tandem', 'twin', 'piggyback', and 'duplex' are all different 'regional' and 'manufacturer-utilized' words for the same thing. However, I am sorry but for that same reason I have to argue that you can not say that a tandem and a piggyback are two different things. Especially given that you are referring to a single handled device as a tandem. That's like saying 'soda' and 'pop' are two different things, with pop being a type of ice cream... I guarantee that if I were to walk into a supply house in your area and ask for a QO 20A tandem breaker (again, google it and look at the images that come up) I would not be handed a single-handled breaker.
The descriptor '-height' or '-size' refers to the device's physical size (1/2" or 1") regardless of the number of handles, and 'tandem' refers to a one-pole, two-handled device regardless of its physical size.
To be honest, if anything it would be your strange terminology that would be confusing... I'd bet anything the OP knew what he was talking about.
Old 06-06-13, 02:48 PM
Nashkat1's Avatar
Gee Matt, you don't think I do? Two oxen or horses yoked side-by-side are pulling in what? Tandem?
We'll see, if and when the OP chimes back in.
Old 06-06-13, 05:39 PM
Exactly. It is two units working as one. It does not imply half-sized oxen.
