Testing A Wire Connector to see if it's Bad
Old 06-05-13, 12:39 PM
I think I have a bad wire connector but need to verify.
Plugged a UPS into it, UPS detect the difference between ground and neutral is greater than 15V.
The UPS is good cause when I plug it into a different outlet, no alarms. Hence, I suspect it's the other one.
With a multimeter, what probe do I need to insert where and check what to confirm it is such. I'm a MM noob
Old 06-05-13, 01:05 PM
ray2047's Avatar
Note readings will be more accurate with an analog multimeter rather than a cheap digital.
  • Black to white
  • Black to ground
  • White to ground
