(Misting Sprayer Timer) Help me figure out how to do this?
Received 0 Votes
Im trying to duplicate this misting sprayer.
I have the timer where im confused is the timer only goes down to a 1 minute setting. So i assume they put the spray time knob "mist on in sconds" in as an override function.
If the timer only allows the pump to come on for a minimum of 1 minute and i wanted a 30 second spray this is how i would do it
My question is what type of switch is this and how would one wire it in?
thanks
mack
thanks
mack
Something like this might work
TDU3003A - SSAC - Time Delay Relay, On-Delay, 120/240V AC/DC Control, 1-1023Sec DIP Select 2-W Cube, 1A Solid State Output
It's only a 1A load, so it may or may not be sufficient for what you need.
Never used one, but hopefully it's a step in the right direction.
