Doorbell light triggers chimes???
Old 06-06-13, 07:06 PM
I am installing a new doorbell button... Button works well. Except when I install the bulb... It triggers continuous chimes. Help?
Old 06-06-13, 07:26 PM
Welcome to the forums.
Is that a mechanical chime or an electronic unit ?
Usually the lamp used in a lighted pushbutton is extremely low draw and won't trigger most doorbells..... but there a few exceptions..... especially with the solid state electronic chimes.
Old 06-07-13, 06:04 AM
I'm thinking mine is a SS unit... : Wireless Doorbell Extender. Checked the manual and called the company... No suggestions. Thoughts?
Old 06-07-13, 06:54 AM
ray2047's Avatar
Yes, that sounds wireless. Make and model number please.
Old 06-07-13, 07:51 AM
STI 32000 Wireless Doorbell Extender
Old 06-07-13, 08:23 AM
My guess is that one of the hot wires may be touching a ground.. Start by reviewing your wiring. I hope this little tip helps.. Good luck, I will try to keep looking for a better answer to give you soon!
Old 06-07-13, 11:56 PM
I was reading the data sheet and it says to use a normally open switch. It must see the lamp as a partial short.
The only way around this problem I can see is to use a small 12-20 vac relay.
Old 06-08-13, 05:39 AM
Information received... Thanks!
